Ground evaporation formula (Water Overlay)
Revision as of 13:28, 2 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "Underground evaporation is calculated per cell. Evaporation capacities: For all underground evaporation, the height of the unsaturated zone is used. : ''H<sub>unsat</sub> =...")
Δw = Δwunsat + Δwsat
Where:
Template:WaterOverlay nav
