How to add and remove a Result type
A number of Grid Overlays can output multiple types of results. One result type will be set as primary result type. Others can be added as Result child type Overlays.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Overlay to edit (Left panel) → General tab (Right panel)
How to set the main Result type of an Overlay:
- Find the 'result type' dropdown menu.
- Select the desired result type.
- Recalculate the overlay.
- The output of the Overlay is now of the desired type.
If the main result type of a Grid Overlay is already configured to another result type, and it is not desirable to lose that particular output, it is also possible to add the desired result type as a Result Child Overlay.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Overlay to edit (Left panel) → Configuration Wizard (Right panel)
How to add a Result Child Overlay to an Overlay:
- Open the Overlay's configuration wizard.
- Continue to the Output Overlays step.
- Make sure the checkbox next to the desired result type.
- Close the configuration wizard.
- Select the added Result Child Overlay.
- The output of the currently selected child Overlay is now of the desired type.
How to remove a Result Child Overlay from an Overlay:
- Make sure the checkbox next to the relevant result type is unchecked.
- The relevant result type is now no longer output by the overlay.
