How to show a unit type in the 3D Visualization
How to add and activate a traffic unit
By selecting the 'Add' button on the bottom of list of units, a new panel with Unit Types appears. By selecting the desired unit from the list, and then the 'Apply' button, the unit is added to the project, but not activated yet. By highlighting the newly added unit on the left panel, the unit details become available on the right side. Here is also a checkbox to set the unit Active in Simulation.
How to Add and activate a Traffic Unit:
  1. Select Current Situation.
  2. Hover Buildings on the ribbon bar.
  3. Select Show Traffic Units in the popup.
  4. Select 'Add' at the bottom of the left panel
  5. Select the desired unit type from the popup panel and apply
  6. Notice a new unit has been added to the unit data overrides list in the left panel
  7. Select the newly added Unit
  8. Set the Unit to Active in Simulation in the right panel
How to edit the amount of units per hour for a particular road that supports your Unit Type
The amount of units per hour can be edited and is used for displaying traffic overlays in the 3D Visualization.
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar) → The Building to edit (Left panel)
How to Edit the amount of units per hour for a Unit Type:
  2. Select Buildings on the ribbon bar.
  3. Select "Roads" in the left panel.
  4. Select the desired road (part) in the left panel
  5. Change the units per hour in the right panel
  6. Optionally change the Function of the road if it does not support your Unit Type.
