Version 2022.2.0
Jump to: navigation, search
Version 2022.2.0 is released on preview.tygron.com on October 1th 2021.
Traffic
  • Traffic is now split per modality: e.g. cars, vans, trucks and buses.
  • NSL data is now loaded into these new modality values for amount and jam factor.
  • Both Noise and NO2 overlays accept grid from other overlays as traffic amounts.
  • Old TRAFFIC_FLOW attribute is no longer used and has been removed.
Globals
  • Can be set with multiple values: e.g. 1 2 3.
  • Combo Overlays tread these globals as separate timeframes, e.g. 1 2 3 results in 3 timeframes.
Water
  • Updated WaterWijzerLandbouw to latest 3.0.0 version.
  • Updated BOFEK_ID to latest (BOFEK2020) version.
  • Water wizard shows objects outside the limit area as inactive and are sorted accordingly.
Custom Geo Plugin
  • Added an example geo plugin for Natura2000 areas. It can be inspected and duplicated to activate and adjust it.
  • Improved custom geo plugin editing.
  • The Editor event SET_ATTRIBUTES for Buildings and Zones has been changed to bring its functionality in line with other similar events.
  • This might impact API users which use this event. The event has been changed as followed:
    • To: k- ids , k- attributes, k- values
Other
  • Fixed adding key points to cinematics
  • Fixed saving Parametric Designs as measures
  • Several smaller bug fixes.
