Global
Global
A global is a number that exists in the project but is not necessarily connected to a specific component. The global can be used, for example in Excel calculations and influence the calculation of an Excel indicator.
Global Uses
When you have created a global the can be used communicate with a Microsoft Excel spreadsheet, when using such a spreadsheet for a (custom) Excel Indicator. Also, globals are currently used to attach to event bundles and hereby influence the progress of indicators. Read more about how to connect the global to an Event Bundle on the events page.
Properties of globals
There is one type of global that can be applied in different ways. A global is always made up of a name of the global and a number. Based on the purpose of the global the number represent an amount or a value which is specified by the name of the global. A global is similar to an attribute but for the entire project rather than for a specific component.
Output
By making use of the SELECT_GLOBAL_WHERE_NAME_IS_GLOBALID query in an Excel you can use globals to create output. It is also possible to connect the global to the budget of a specific stakeholder to directly influence the budget during a session.
Input
By making use of the UPDATE_GLOBAL statement in generating a query for an Excel, the global is used to generate input by an Excel calculation. The second way of using a global as input is by connecting the global to an Event Bundle. The value of the global can be used in the event to influence an indicator.
Add and remove Globals
Template:Editor ribbon
The Left Panel allows you to add, duplicate, and remove globals.
How to add a global:
  1. In the ribbon header, select "Indicators".
  2. In the ribbon bar, select "Globals".
  3. In the left panel, select "Add".
How to duplicate a global:
  3. In the left panel, select the global you wish to duplicate.
  4. In the left panel, select "Duplicate".
How to remove a global:
  3. In the left panel, select the global you wish to remove.
  4. In the left panel, select "Remove".
How to edit Globals
Selecting a global makes its static properties adjustable in the Right Panel.
Selecting a global in the left panel makes its properties adjustable in the right panel.
Global properties
Stakeholder properties
Name
Each global has a name, this is shown in the left panel in the list of all globals that are created in the project. The global Name is the name of the Global ID which is used in queries.
Visualization Name
The Visualization Name is the name that is visual in the budget indicator en is Set Point is used, the name that is visible in the 3D world.
Start Value
The value that is represented with this global.
Assign to Budget
With this checkbox you can decide if you want to attach the value to the budget of a certain stakeholder or not. If you check this box the value is automatically counted as money for the budget.
Stakeholder
The stakeholder dropdown menu is only available when the checkbox is checked. Here you decide to which of the stakeholder you attach the budget value to.
Remove Point
With the remove point option you can remove the visual global in the 3D world. The global is still present in the project, as you can see in the right panel, only it is not visible anymore in the 3D world.
Set Point
With the set point option you can let a global be displayed at a specific point in the 3D world. You can attach the global to a specific place in the 3D world regardless whether there is a construction. More information about how to draw a point in the 3D world is explained on the brush panel page
