Install
What is an installer in relation to the Tygron Engine?
An installer is a software component used for the installation, maintenance, and removal of the Tygron Engine software.
What is the function of the installer in relation to the Tygron Engine?
The Tygron Engine is an application which needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup.
Downloading the installer
Before you can install the Tygron Engine (LTS) you first need to download the installer.
How to Download the installer for the Tygron Engine:
  1. Open your browser
  2. open https://engine.tygron.com/
  3. Select "Windows (64 bit) Installer"
  4. "TygronEngineWin64.msi" will start downloading
  5. Once the download has been completed proceed to the next step, "Running the installer"
Before you can install the Preview Tygron Engine you first need to download the installer.
  2. open https://preview.tygron.com/
Before you can use the Tygron Engine you first need to run the installer.
How to Install the Tygron Engine:
  1. Open "TygronEngineWin64.msi"
  2. the installer will install the Tygron Beta Application
  3. A desktop shortcut and a start-menu shortcut will be created
Launching the Tygron Engine
Once the installer has completed you can launch the Tygron Engine Beta application.
How to Start the Tygron Engine Beta Application:
  1. Launch "Tygron Engine" from the desktop shortcut or the start menu
  2. You will be prompted with the login screen.
