Roadmap
The R&D department of Tygron develops new technology for the Tygron Engine. The long term planning which shows the introduction of new features and versions is called the Roadmap. Currently we are working on following long term projects, next to minor updates, bug fixes etc.
Server release cycle
The Tygron Engine development process is defined by testing and releasing quarterly previews to final release on the LTS (Long Term Support) version.
Servers
test.tygron.com:
This server is for testing purposes and is updated constantly. Customer involvement is by invitation only.
preview.tygron.com:
The preview server is updated quarterly. This cycle consists of 2 months roadmap development and 1 month user feedback fixes and additional bug fixes.
engine.tygron.com (LTS)
Updated once per year. After testing and running the previews for several months with additional user feedback, the final LTS version is released.
What to expect?
Current development on test server
- Fixing PDOK software download limit of a 1000 units for buildings. This will be a hotfix.
- New Distribution network. It will be possible to import and export different types of networks and their attributes via Excel using TQL. (Tygron Query Language)
- Overlays will run on the GPU with the possibility of having more instances of every type. Also a new AVG overlay based on attributes.
- Terrains have attributes now and they can function as being subterranean. For example peat or clay surfaces.
Previous versions this year
Further development for 2017
The following developments are still in the planning stage:
- Continuing development on the HEAT network system.
- More R&D into GPU accelerated calculations.
- New Selection and Overlay system. The current system is too heavy and is restricting further development. We are moving to an GPU accelerated system.
- Start menu overhaul and new domain management and project selection info.
- Improvement of loading GEO data and more flexibility for Clients to customize the data.
- Improving the UI based on user feedback.
- Generic Grid Overlays. User can make custom overlays based on his own formulas.
Version numbers
A brief explanation about the meaning of the version numbers.
Version numbers consist of 4 digits: For example: 2017.1.4.2
- 2017: The main number represents the year of LTS release.
- 1: This represents the preview release, in this case the first quarter of the year.
- 4: Represents a small update for a feature/bug where the API has been changed.
- 2: Represents an even smaller update or hotfix where the API explicitly does NOT change
