Version 2017.0.7
Version 2017.0.7 was released on December 10th 2016 on engine.tygron.com.
Improvements
  • Popups visible in 2D overview map.
  • Overlays can have multiple sub overlays (to prevent too much icons in navigation bar).
  • Improved feedback on Excel errors.
  • Slightly better roof colors.
  • Option to set languages for your project.
  • Option to transfer all ownership from one stakeholder to another.
  • Multi demolish option now available in multi selection panel.
  • Parent structure of Zones is editable.
  • Color picker for TQL color statements and Object attributes.
  • Measure buildings support the new permission Popup.
  • Option to create your own Overlay legend.
  • COLOR attribute now has a color picker.
  • Option to set attention flag to panels, attention triggers arrows on screen.
  • The editor panels remain visible during a test run (so you can check values and helps with debugging Excelsheets).
  • Loading and removing Area's is accelerated (factor 500 times faster).
  • A number of GUI enhancements in the editor, wizard and viewer.
  • The popup template is fixed and is applied directly if you are using a template for your project.
  • NEW TQL query: LOTPOLYGONS, with this selection you can create a popup that selects an area for example to pointout where there is nuisance. (in Excel visible as 1 [data] and 0 [no data] and the polygons are also stored in popups)
  • Popups can retrace the outcome (by arrows) of a requested selection based on the polygons in this selectioin and if relevant also activate overlays.
  • Template popups can contain answers that adjust attributes.
  • Check the Cache at startup of your project is faster.
  • Permission popup shows the results of the requested action on the indicator(s).
  • Permission popup runs along all zones (spatial plans) and will provide the outcome in one answer. In the Zone panel all that are included in the request are visible.
  • Spatial planning: Only the latest approved plan is used in the project. Sometimes there are as many as 10 plans and before you could also get 10 times the number of zones, often with the same values.
  • Video/hardware test is faster and more robust.
  • Intel cards support is better.
  • Racing conditioning check in excels. If two excels update the same value in the world, the engine now shows an error rather than pick one of the values. This is also a check not two TQL labels refer to the same cell in Excel. NOTE: Please check old projects. It could give errors in excel indicators.
Bugs
  • Conversion script to update older versions.
  • Several UI bugs.
  • Template heightmap fixed.
  • Shader bug in Terrain (causes black screen).
  • US feet roundoff fixed.
  • Broken mouse cursor fixed.
  • Web panel scrolling fixed.
  • Use Esri for basemap color instead of Cyclomedia
  • Fixed appearing hover panel.
  • Fixed brush set disable/enable
  • Fixed global panel
  • Fixed picking for underground buildings.
  • Fixed TQL query tool for custom attributes
  • Activating a Measure does not trigger and exception when already active.
  • Several editor testrun related GUI bugs.
  • Connection Timeouts when starting a new session or recalculating a large grid are fixed.
  • Fixed sloping roofs
  • Fixed recognition of bridges in the BGT.
  • Fixed Linux & Mac bugs
  • Fixed beamer function.
  • Fixed touchscreen/zoom.
  • Fixed height tool.
Performance
  • Higher framerate on low-end systems, resulting is a more responsive interface.
  • Improved grid calculation speed by 20%.
