Basic skills tutorial
Adding an indicator
In this assignment you will add a standard indicator to the project. This indicator is a calculation model available in any project. Once added, it will automatically start to calculate and influence the score of the stakeholder for whom it was added.
- Select "Indicators" → "Indicators" in the ribbon.
- At the bottom of the left panel, select the Traffic Noise indicator type.
- Select "Add". Notice the indicator is added to the topbar.
The indicator can now be selected in the topbar.
For more information on this topic, visit the following pages:
Adding and removing a construction
In this assignment you will create a construction in the base-state of the world. This means that the construction will be present at the start of the session. This will occur in 2 steps: first the construction will be made part of the project, and then it will also be assigned a location in the world.
After that, you will remove a construction from the base-state of the world. This means the construction will not be present at the start of the session. It will not be removed from the world separately, but will be removed entirely.
- Select "Geo data" → "Buildings" in the ribbon.
- Select "Add" in the bottom of the left panel.
- See the properties of the building appear in the right panel.
- Select "Draw Area".
- Find a location in the world which is not colored grey. Places which are not grey are valid to draw.
- Create a selection in the world which is at least partially green.
- In the brush panel, select "Apply Selection".
- Select a building by selecting it in the list in the left panel, or by selecting it in the world.
- Select "Remove".
- Confirm that you wish to remove this construction.
Loading in GeoJSON
In this assignment you will load in a GeoJSON file into the editor. A file has been prepared with a number of shapes which overlap with some of the roads in the project. The file also contains (fictional) traffic intensity values. By loading in this file into the editor, the building values of the roads can be adjusted to have the traffic intensities as defined in the file.
Download the excample traffic intensities file. It can be found here: Road Intensity file. Unpack it before starting.
- Drag the GeoJSON file ("roads-intensity-shapes.geojson") into the editor.
- Select "Import Building Values".
- Select "only buildings with Category: ROADS".
- Make sure "TRAFFIC_FL" is checked.
- Enter "TRAFFIC_FLOW" in the field next to "TRAFFIC_FL".
- Select "Send".
To see the loaded traffic intensities, it is possible to simply view the roads in the 3D world. The affected roads will have more cars on them then they had before. For greater insight into the effects of the new data, it is also possible to add an overlay for traffic noise or traffic intensity.
