Basic skills tutorial
The best way for building experience with the Tygron Engine is by actively using it. Especially after a training, staying active in the Engine is the best option for consolidating what you've learned. To help with this proces, this page offers a number of assignments to keep active.
These assignments can be done in the project "ClimateGame". This project is available in all domains.
Starting the project
After logging in, you will find yourself in the main menu. Select "Edit Project", and then select the "ClimateGame 5" project. It will begin to load. When the editor has loaded, you will see an interface with a ribbon menu at the top, and the 3D World in the center. If you don't want to save the adjustments you make in these practice assigment, you are now ready to begin. However, if you do want to save all the adjustments you practice with these assignments you need to make a personal copy of the ClimateGame5 project.
- Select "File" in the ribbon.
- Save As left panel, adjust the name to a self chosen project name.
- Select "Save".
This new created project can be edited and saved whenever you want. You are now ready to begin these assignments.
Guided Assignments
These assignments will guide you step-by-step through some simple use-cases.
Adjust the 3D world in the editor
In this assignment you will adjust the 3D world. After this practice you can edit your base project in case you need to change the 3D world after loading a new project in the wizard.
The assignment consist of 3 parts.
1) Remove a construction in the 3D world to create an empty spot where you can put a new construction.
2) Add a new construction of the category Education of the Education Luxuray type.
3) Edit the new Education Luxuray building to a building with a floorhight of 10 floors.
If you need more information to exicute these assignments go to the specific wiki pages with the indepth information.
1) How to remove a construction in the 3D world
2) How to add a construction in the 3D world
3) How to edit a construction in the 3D world
For more information on this topic, visit the following pages:
Adjust the 3D world in a session
The assignment consist of X parts.
1) Add a new action menu to the Uni real Estate Stakholder and name it Education
2) Add a the build Education Luxary option to the action menu
3) Build a Education Luxary building in the 3D world
4) Notice the test run has started. Stop the testrun and notice the new build construction disappears.
1) How add a action menu
2) How to add a construction to the action menu
4) What is a Testrun
Adding an indicator
In this assignment you will add a standard indicator to the project. This indicator is a calculation model available in any project. Once added, it will automatically start to calculate and influence the score of the stakeholder for whom it was added.
- Select "Indicators" → "Indicators" in the ribbon.
- At the bottom of the left panel, select the "Traffic Noise" indicator type.
- Select "Add". Notice the indicator is added to the topbar.
The indicator can now be selected in the topbar. This means that the current stakeholder will see it during a session. However, when you switch to the perspective of a different stakeholder the indicator will not be directly visible. This is because the indicator has not yet been added to the perspective of other stakeholders.
- In the top right of the editor, switch to a different stakeholder perspective. Select "Stakeholders" → "Stakeholders" in the ribbon.
- In the left panel, select the current perspective's stakeholder.
- Notice that under the stakeholder's entry, a list of levels appear. Select the first level.
- At the bottom of the right panel, use the dropdown menu to select "Traffic Noise".
- Select "Add".
- Notice the indicator is added to the topbar.
Adding and removing a construction
In this assignment you will create a construction in the base-state of the world. This means that the construction will be present at the start of the session. This will occur in 2 steps: first the construction will be made part of the project, and then it will also be assigned a location in the world.
After that, you will remove a construction from the base-state of the world. This means the construction will not be present at the start of the session. It will not be removed from the world separately, but will be removed entirely.
- Select "Geo data" → "Buildings" in the ribbon.
- Select "Add" in the bottom of the left panel.
- See the properties of the building appear in the right panel.
- Select "Draw Area".
- Find a location in the world which is not colored grey. Places which are not grey are valid to draw.
- Create a selection in the world which is at least partially green.
- In the brush panel, select "Apply Selection".
- Select a building by selecting it in the list in the left panel, or by selecting it in the world.
- Select "Remove".
- Confirm that you wish to remove this construction.
Loading in GeoJSON
In this assignment you will load in a GeoJSON file into the editor. A file has been prepared with a number of shapes which overlap with some of the roads in the project. The file also contains (fictional) traffic intensity values. By loading in this file into the editor, the building values of the roads can be adjusted to have the traffic intensities as defined in the file.
Download the excample traffic intensities file. It can be found here: Road Intensity file. Unpack it before starting.
- Drag the GeoJSON file ("roads-intensity-shapes.geojson") into the editor.
- Select "Import Building Values".
- Select "only buildings with Category: ROADS".
- Make sure "TRAFFIC_FL" is checked.
- Enter "TRAFFIC_FLOW" in the field next to "TRAFFIC_FL".
- Select "Send".
To see the loaded traffic intensities, it is possible to simply view the roads in the 3D world. The affected roads will have more cars on them then they had before. For greater insight into the effects of the new data, it is also possible to add an overlay for traffic noise or traffic intensity.
