Support:Layout Convention
This pages describes the way the pages are layout to ensure all pages are consistent. It means as an example how to layout the different pages on the wiki.
After reading this page
- You've learned how to layout pages on the Tygron Wiki
The first thing on the page is always describing what the user will know when he has finished reading the current page.
Main Structure (Definition)
The main Structure of most pages is divided into 3 parts.
What is it?
The "What is it?" gives the user an explanation of the definition of the term.
- '''Indicators are named after Key Performance Indicators, by which organizations evaluate their success. Key Performance Indicators serve as a means for identifying potential improvements, and as a metric for the degree to which those improvements have been successful.''''
How does it relate to the Tygron Engine
The "How does it relate to the Tygron Engine" gives the user an explanation of the relation between the term and the way it is implemented in the Tygron Engine.
How can the user change it
The "How can the user change it" relates to how changes can be made to the current topic in the engine.
Adding / Removing
Editor → Editor Menu bar → 3D World → Constructions
Each topic refers at the top of the subject to the editor interface in the above convention. This way users can easily find the location where changes can be made.
"Adding / Removing" explains how users can add and remove elements to the editor. The topic ends with images, so the user gets a graphical representation of the steps to be taken to reproduce the action.
See the "Adding Constructions" example below.
Adding constructions
- 1. Right click on the list of constructions
- 2. Select 'Add' from the context menu. This adds new construction to the construction list, named "0_Building".
- 3. The new construction is not present in the 3D World yet, since no selection has been added to the Construction yet.
- 4. For details on adding / changing a selection from a construction see see below.
Context menu after right clicking (sparse construction list)
Context menu from listing (filled construction list)
Changing
"Changing" explains the detailed properties of this element and how users change this properties of elements. It describes:
What is this property
"What is this property"describes what this property is.
Where is this property used
"Where is this property used"describes on which place this information is presented to the players.
How can it be changed
"How can it be changed"describes the technical details on how this information can be changed by the user.
Main Article
The Main article convention is used to reference to a topic which has a more detailed description.
For example:
- Main article: Budget (Indicator).
