Requirements
System Specifications
Tygron products utilize gaming technology as their driving force, most notably the 3D visualization. This technology does mean a computer must meet certain requirements to be able to run Tygron products. Your hardware is automatically categorized into the following scores. The total score of your computer is based on the lowest scoring component, and will affect both the default graphical settings and the ability to load in larger project areas.
CPU (Processor) Memory (RAM) GPU (Videocard)* Recommended system Notes on score
LOW Celeron At least 4GB RAM Benchmark score below 1000
with OpenGL 4.0, GLSL 400
Systems with this score are not fully supported. Graphical issues and slow responses can be expected.
MEDIUM AMD Athlon
Core 2
Pentium
At least 4GB RAM Benchmark score above 1000 This is the minimum recommended score.
HIGH i3, i5 At least 8GB RAM Benchmark score above 1500+ HP Omen 15-ax-025nd
This model is currently in active use at Tygron.
For creating and opening projects with a map greater than 5x5km, at least HIGH is required.
EXTREME i7 At least 16GB RAM Benchmark score above 5000 HP Omen Desktop 870-242nd
* We have found that NVIDIA cards provide the best stability in comparison of Intel and AMD. Therefore, we can strongly advise NVIDIA Geforce GT950 for desktop computers and NVIDIA Geforce GT950M for laptops (or better!). We recommend looking for cards in the high-end consumer segment (GeForce), as the Tygron Engine does not make use of the extreme-precision capabilities of the more expensive Quadro cards.
Screen resolution 1280 x 800 pixels or higher
Operating system Windows 7, 8, 10 (64 bit)
Internet connection ** Required
** There are no specific requirements to the internet connection. It is however advisable to test the available connection when preparing for a session.
Software Guide
Video card Drivers
Please make sure you have the latest drivers installed for your video card from the original manufacturer. Below a list of video card driver download locations:
Explanation on the hardware
Because the Tygron Engine is 3D visualization software, the various requirements list above must all be met. A brief clarification of why each requirement is relevant:
CPU
The processor is the general "computing" part of a computer, performing most functions of a computer. General responsiveness of the application and the computer itself are dictated by the processor.
RAM
GPU
Often in the form of a videocard, the graphical processor deals with all visualization matters. This component makes the 3D visualization of the Tygron Engine possible.
Screen resolution
The Tygron Engine is a complex tool, and require sufficient screen space to allow an overview of all options and information panels.
Internet connection
The core technology of the Tygron Engine is cloud-based. Your computer needs to be able to visualize the application and keep data about the project available, but the really heavy lifting in terms of calculations is done in the cloud. This means you need to be connected to the internet, and the better your internet connection the more responsive the application will be when dealing with data updates.
