Rainfall Overlay tutorial
Getting Started
  1. Contact Tygron Support to request the Kockengen Tutorial project
  2. Open the Tygron Engine, logon with your user name and password and open the project Kockengen Tutorial
  3. Download and unpack the content of this zip-file on your desktop: [1]
Open the Tygron Engine and start the project Kockengen Tutorial. The project will appear:
Adding a Rainfall Overlay
In this step you will add a Rainfall Overlay. Follow these steps:
  1. Go to Overlays, in the Geo Data ribbon and select Add Rainfall. The rainfall overlay appears on the left-side-panel. And in the overlay bar on the right side of the map: Kockengen figure02.PNG
  2. On the right side panel, you find four tabs: General, Keys, Legend and Attributes. Take a moment to familiarize yourself with these tabs.
    • General contains the most common information necessary to interpret the rainfall overlay.
    • In Keys you can relate 'Keys' of the rainfall overlays to attribute information stored in the 3D world.
    • Legend allows you to customize your legend
    • Attributes contains the settings of your overlay.
  3. Click on the Configuration Wizard button. With the Rainfall Overlay Wizard, you can configure your water system, this includes:
    • The setup of the weather boundary condition
    • Definition of the water system, including water level areas (peilgebieden) and sewer districts
    • Setting of hydrological parameters
The Rainfall Overlay Wizard
With the Rainfall Overlay Wizard you can configure your water system, including surface water and sewer districts. In this part of the tutorial you need to have prepared the following GeoJSON-files:
  • waterlevelareas.geojson
  • sewerdistricts.geojson
  • weirs.geojson
  • overflows.geojson
Some tips in preparing the required vector-files:
  • All files need to have a coordinate reference system (CRS) defined. The Tygron Engine will automatically reproject the vectors to its internal local mercator projection.
  • Hydraulic structures (weirs, culverts, pumps and overflows) need to overlap the two areas (water level areas or sewer areas) they connect. Only structures which connect two areas will be interpreted as being part of the water system.
Step 1: defining the weather
Press Next to proceed to the Weather panel, here the user can define rainfall and evaporation input. Change all numbers and the according to this picture:
By this setting you have defined a rainfall event:
  • Uniform rainfall in 120 minutes
  • With a total rainfall amount of 50mm
  • With a dry period after rainfall of 120 minutes, so a total simulation time of 4 hours
  • Reference evapotranspiration will be assumed on 1.5mm/day
Step 2: setup of the water system
Press next to proceed to the introduction screen: Setup Water System. Here you can define your water system using the prepared GeoJSONS.
Step 2.1: adding water level areas
Press next to the screen for importing water areas. A water level area is an area with a spatially uniform water level varying in time. Variation is caused by rainfall + evaporation on the surface water, inflow from sewer areas, inflow from the surface and groundwater inflow.
There are three options to define your water system:
  • Import Water Areas: allows you to import a set of water level areas from an external dataset
  • Generate Water Areas: allows you to define 1 water level area for your project area
  • Do Nothing: the surface water system effectively has infinite storage
Select Import Water Level Areas and press Import Water Level Areas. The Geo Data Wizard will open. We will import waterlevelareas.geojson. Use the following attributes in the GeoJSON file as attributes for the Rainfall Overlay:
  • WATERLEVEL: the initial Water Level in the water level area (m + datum)
  • OUTLET: the outlet capacity of the Water Level (m3/s)
  • ID: the identification of the water level area
  • NAME: the name of the water level area
Steps in the Geo Data Wizard:
  1. Select Import a GeoJSON file and press Next. Press Select File and locate the waterlevelareas.geojson. Press Open and press Next.
  2. An overview of your areas is generated; see right-side pictures. Press Next
  3. In the next step you can filter features based on attribute filtering. We skip this step by pressing Next
  4. We assign names to the water level areas using the NAME attribute from the geojson; ; see right-side pictures. Press Next
  5. We select all attributes, importing all attribute data from the geojson, and press Next
  6. We assign the WATERLEVEL attribute of the GeoJSON to the WATER_LEVEL key of the overlay and the OUTLET attribute of the GeoJSON to the OUTLET key of the rainfall overlay; see right-side pictures
  7. At Finalize we press Finish to upload the areas to the server
After importing your water level areas you can review all parameters by opening the selection menu. Take some time to review the attribute values. What is the meaning?
Step 2.2: initial groundwater level
In step 2.2, you can specify ground water levels. By default, ground water levels are assumed to be the same as the water level in the water level area (see previous section). Alternatively, the user can specify pre-defined initial groundwater levels (GHG,GLG and GVG for the Netherlands) or a GeoTiff with ground water levels in m below surface; see right-side pictures.
Step 2.3: adding sewer areas
Sewer districts are represented by areas which have one storage value [m], uniform in space. Sewer storage will vary in time by sewer inflow from connected buildings (buildings, roads, etc), pumped outflow to a WWTP and sewer overflow to surface water. Press import sewer districts and import the file sewerareas.geojson via the GIS wizard. Assign the following attributes:
  • ID: identification of the sewer district
  • NAME: name of the sewer district
  • POC: pump capacity assigned to the sewer district [m3/s]
  • STORAGE: storage of the sewer district. [mm]
Follow the steps in the Geo Wizard according to the steps described in the water level areas section:
  • At step 5, multiply the attribute value in the GeoJSON (mm) by 0,001 (conversion to m); see right-side pictures.
  • At step 6, assign the the STORAGE attribute to the SEWER_STORAGE key and the POC attribute to the SEWER_PUP_SPEED key
Take some time to review the attribute values in the imported area Kockengen. What is the meaning?
Step 2.4: adding hydraulic structures
You can import the following hydraulic structures:
  • Weirs, connecting different water areas. Flow between two water areas is computed with the weir formula, using the water level of the connected water areas(1).
  • Culverts, connecting two water areas. Flow between two water areas is assumed to be equal to a fixed flow capacity(1).
  • Pumps, connecting two water areas. Flow between two water areas is assumed to be equal to the pump capacity(2).
(1) In cases in the Netherlands: deze kunstwerken zijn typisch peilscheidende duikers en stuwen. (2) In cases in the Netherlands: deze pompen zijn typisch voor onderbemalingen en zoetwatervoorziening in droge tijden.
2.4.2 Adding Culverts & 2.4.3 Adding pumps Similar to the import procedure of Weirs, you can add pumps and culverts. They have a similar function as the govern the flow from one water level area to another.
2.4.4 Adding Overflows You can upload the overflows.geojson by selecting Import Overflows in the Weirs screen. We will import weirs.geojson, using the following attributes:
  • LEVEL: the crest level of the overflow
  • CAPACITY: the overflow capacity of the overflow
Follow the Geo Data Wizard similar to the procedure at importing weirs (see 2.4.1 Adding Weirs) and view the result. What do the values mean?
2.4.1 Adding Weirs
You can upload weirs.geojson by selecting Import Weirs in the Weirs screen and pressing Import Weirs. We will import weirs.geojson, using the following attributes:
  • NAME: the name of the weir
  • ID: identification of the weir
  • WEIR_HEIGHT: the crest height [m + datum]; to be assigned to the WEIR_HEIGHT key
  • WEIR_WIDTH: the width of the crest [m]; to be assigned to the WEIR_WIDTH key
  • WEIR_COEFF: the weir coefficient, accommodating all losses; to be assigned to the WEIR_COEFFICIENT key
In the Geo Wizard follow the steps:
  1. Select Import a GeoJSON file and press Next. Press Select File and locate the wiers.geojson. Press Open and press Next.
  2. An overview of your areas is generated as below. Press Next
  4. We assign names to the water level areas using the NAME attribute from the geojson and press Next
  6. We assign the WEIR_HEIGHT attribute of the GeoJSON to the WEIR_HEIGHT key of the overlay, the WEIR_WIDTH attribute of the GeoJSON to the WEIR_WIDTH key of the rainfall overlay and the WEIR_COEFF attribute of the GeoJSON to the WEIR_COEFFICIENT attribute of the rainfall overlay.
  • LEVEL: the crest level of the overflow; assign to the SEWER_OVERFLOW overlay key
  • CAPACITY: the overflow capacity of the overflow; assign to the SEWER_OVERFLOW_SPEED overlay key
Step 3: setup of coefficients
In this step you can adjust default parameters related to the surface (e.g. roughness), sub-surface (e.g. conductivity) and infrastructure (e.g. is a type connected to a sewer or not). As we do work with a 3D world containing allot of data, the determination of model-coefficients can be complex. E.g.:
  • A manning roughness coefficient can be related to the surface type (e.g. clay) if no infrastructure present. If infrastructure is present (e.g. a road), the value of the road will be used, and the value of the surface type will be ignored
  • An infiltration parameter can be related to the surface (land cover), infrastructure or underground (sub-surface). The minimum value of the three will be chosen as being representative for a cells infiltration rate.
You can inspect the values by going to the pages. We will leave everything to default by pressing next (4x)
Step 4: Interactions
The Rainfall Overlay can produce one or more results. By default Water Stress is chosen, which is the maximum water depth at simulation. For water cells a maximum allowed increase model parameter is set. Below that depth no water stress will be perceived. Here you can choose to visualize your water system network in the rainfall overlay:
  • Display Water System network: shows the network of the water system
  • Display Weirs with Panels: shows all hydraulic structures, allowing the user to overwrite structure settings
  • Display Water level Areas with Panels: shows all centroids of water level areas, allowing the user to overwrite initial water levels and outflow capacity
Step 5: Output Overlays
Step 6: Input Overlays
The Rainfall Overlay uses several input parameters to compute output. These input overlays can be visualized in the Input Overlays section. Select the manning roughness value [m/s^1/3]
Press Finish to finalize the wizard
After completion of the wizard
After completing the wizard, you need to Refresh Grid to recalculate the inundation grid; every time you change a parameter the model will be recalculated if you press Refresh Grid.
When finished, please explore the following interesting features:
  • In the General Tab you can Download a Water Balance XLSX-file. Please explore
  • Below there is a summary. Interesting features are the water balance summary and the Max Courant number.
  • In the General Tab. If you change the number and press refresh grid (the model will re-calculate), the Courant number will change as well. Can you explain?
  • In the General Tab you can press Change Grid to change the grid cell size. Can you see the difference, and see the impact on the Courant number?
  • In the General Tab you can export the result as a GeoTiff. Please do so and visualize your result in QGIS.
  • Open the Configuration Wizard again. Select more and/or different result types. Can you display and interpret the results?
