Ownership
After reading this page:
  • you've learned about ownership
  • you've learned how ownership relates to the Tygron Engine
  • you've learned how to change ownership
  • you've learned about the ownership overlay
Ownership
The ultimate and exclusive right conferred by a lawful claim or title, and subject to certain restrictions to enjoy, occupy, possess, rent, sell, use, give away, or even destroy an item of property.
Ownership may be corporeal (title to a tangible object such as a house) or incorporeal (title to an intangible object, such as a copyright, or a right to recover debt). Possession (as in tenancy) does not necessarily mean ownership because it does not automatically transfer title.
From: http://www.businessdictionary.com/definition/ownership.html
The importance of ownership in the Tygron Engine
Actions can normally only be performed on property that is owned by the acting stakeholder, or with permission from the actual owner. To accommodate this, stakeholders can buy and sell land from and to each other, opening all new ways to approach the objectives. It is one of the mechanics that can force players to communicate and cooperate directly with each other. See also land transactions.
Ownership can be assigned on two levels in the Tygron Engine; on the level of individual buildings, or as complete areas. Ownership can be assigned to both playable as non playable stakeholders; in case of the latter, the non playable stakeholder can be represented by the game facilitator.
How to change ownership in the tygron engine
Ownership can be assigned on two levels; individual constructions and complete areas. The individual ownership assignment takes place on the Edit Construction panel, with a drop down menu in an input field called "Owner". Assigning a whole area's ownership takes place in the stakeholder panel and on a separate Ownership panel
Individual construction ownership
EditorEditor Menu Bar→3Dworld→Constructions
Area ownership
EditorEditor Menu Bar→Stakeholders→Stakeholders or EditorEditor Menu Bar→3Dworld→Ownership
The ownership overlay
