Distance Overlay
What the Distance Zone Overlay is
The Distance Zone Overlay is an Overlay which is used for displaying distance zones around constructions, like industry. The distance zone is situated around the affected construction(s). The distance you want to set for a construction can be adjusted in the function value tabel. There also exists a "Count Hits instead of Distance" option to count the number of occurrences of the construction(s) in the zones. When added to your project, the distance zone overlay can be activated by clicking the corresponding icon in the overlay panel on the right site of the 3D World. An example use case for this overlay can be found on the Usecase Distance Overlay page.
The Distance Zone Overlay can be found as the DISTANCE_ZONE Overlay in the editor.
Adding and removing the Distance Zone Overlay
Template:Editor ribbon
Adding and removing overlays is a generic process, however, certain overlays are dependent on other assets being present too, such as indicators, terrains, vacancy, images, etc. For more information please refer to the respective main articles for the specific overlays.
How to add the Distance Zone Overlay:
  1. Select in the editor 'GEO DATA' from the ribbon
  2. Select 'Overlays' > 'Edit overlays' from the ribbon bar
  3. Select the DISTANCE_ZONE Overlay from the drop down menu on the bottom of the left panel or pick directly from the menu that opens when you select Overlays
  4. Select 'Add' from the bottom of the left panel
  5. The overlay icon will now appear in the right overlay bar
How to remove an overlay:
  3. Select the desired overlay from the list of active overlays on the left panel
  4. Select 'remove' from the bottom of the left panel
  5. Confirm the removal in the pop up confirmation message
Sometimes it can be convenient to duplicate an already existing overlay. To do so, follow the steps for removal, but select 'Duplicate' in stead of 'Remove'.
Selecting Count Hits instead of Distance option
How to Select the Count Hits instead of Distance option:
  2. Select 'Overlays' from the ribbon bar
  4. Select General in the right panel
  5. Check-mark the "Count Hits instead of Distance" option in the right panel
