How to configure the Water Overlays
Revision as of 11:56, 24 October 2018 by Godelief@tygron.nl (talk | contribs) (→Time-controlled flow rate in Breach)
This page describes several use cases and examples of configurations in the Flooding Overlay.
To create a variable Outlet Q in a breach area, a CSV (comma-separated values) file can be imported. Below the steps on how to create such a breach area. For this example we create the CSV in Excel, but you can also use another program to create the CSV.
How to set-up your CSV in Excel:
- Open Excel.
- In the first column, define your time units. This can be in seconds, minutes, hours or days.
- Add the corresponding flow rates per unit in the second column.
- Save the Excel as a CSV.
How to import the CSV as the flow rate:
- Either add a breach area or have your GeoJSON file with your breach area ready. The area should have at least a breach_floor attribute.
- Add a Flooding_(Overlay).
- Go to the Configuration Wizard of the Flooding Overlay.
- In step 2.1 either select the attribute that specifies your breach_floor or import your GeoJSON file.
- Click on Next.
- In the dropdown menu, select your breach area. Now click on Add.
- Import your CSV file by selecting the CSV file.
- Select the time units in your file.
- Select the seperator for your file.
- Click on Apply.
