Function
Functions
A function is a purpose or destination for something. In the context of spatial planning, a function specifically indicates the purpose of a building or other type of construction. A corporate skyscraper has an "office" function. A house has a residential function. A park has a leisure function.
How functions relate to the Tygron Engine
In the Tygron Engine, functions are used to refer to specific types of building. Every construction has assigned to it what type of construction it is, in the form of a function. Functions can also exist separately from constructions, as a definition of a type of building. Although many functions may exist in a game, not all functions need to be used.
Function usage
There are two ways functions can be used. Primarily, a function is used
Changing functions
This section deals with changing the values of the function itself. For changing the function of a construction, see changing constructions.
The function values editing screen.
Adding functions for editing
By default, functions are not yet available for editing. To edit them, they must first be added to the "Function Values" panel. When they are added, their properties can be altered as desired. Adding functions can be done by following these steps:
How to add a function for editing:
  1. Click "Add".
  2. Select the desired function in the function selection window.
  3. Find the function in the list in the "Function Values" panel.
Adding new functions
It is possible to create new functions by duplicating existing functions. The properties of these duplicated functions can be changed separately from the original function. A function can be duplicated as often as desired. Adding new functions can be done by following these steps:
How to add a new function:
  1. Select a function from the list to use as template.
  2. Press "Duplicate".
  3. Find the duplicated function at the bottom of the list.
Changing function
How to change the properties of functions:
  1. If the desired function is not yet present in the list, add the function to the list.
  2. Find the column with the property you wish to change.
  3. Change the value in the row of the function and the column of the property.
Editing the floor area of Social Housing.
There are many properties to be edited.
Changing effects on custom indicators
How to change the effect of functions on custom indicators:
  1. If the desired function is not yet present in the list, add the function to the list of function values
  2. Find the column with the indicator for which you wish to change the effects
  3. Change the value in the row of the function and the column of the property value
Changing the effect of offices on the economy indicator.
For each custom indicator in the game, two properties exist. Each property has its own column in this panel.
Indicator
The effect on the custom indicator. For each 100m² of a function that exists in the game area, this value is added to the indicator. You can change this value by changing the numerical value in this field.
Indicator (cumulative to max)
The maximum effect of this function on the custom indicator. No more then this value can be achieved with this function alone. If the total effect would exceed this value, the effect is capped at this value, and constructing more of the same function does not have any more effect. You can change this value by changing the numerical value in this field.
