Evaporation model (Water Overlay)
Revision as of 12:24, 2 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "Water can evaporate from the hydrological model over time. Multiple forms of evaporation are implemented. All forms of evaporation can be implicitly activated and deactivated...")
Surface evaporation model
Underground evaporation model
Underground evaporation can be implicitly activated or deactivated by setting the relevant properties of all terrain types and constructions to appropriate evaporation values. If the relevant properties are set to 0, no underground evaporation will take place. Underground evaporation is also explicitly deactivated when the underground model is deactivated.
The rate of evaporation is determined by the weather's evaporation rate, and either the construction's WATER_EVAPORATION_FACTOR or the surface terrain's WATER_EVAPORATION_FACTOR.
