Terrain water (Water Overlay)
Revision as of 11:05, 3 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay terrain attribute |WATER |boolean |Surface |Whether the specified terrain is a water terrain. }} ====Water==== Water terrains are processed by the water model in a...")
Template:Overlay terrain attribute
Water
Water terrains are processed by the water model in a specific manner before the simulation is started. For each water terrain in the 3D world, the bottom of the water body is treated as a land surface in the same fashion as dry land. Water is then placed on it on the surface layer, up to the level defined by the overlapping water level area's WATER_LEVEL attribute. Terrains not marked as water terrain are not initiated with water.
