Culvert (Water Overlay)
Culverts are assumed to have a spherical cross-section.
A culvert is a line-based constructions.
Icon Attribute Unit Description Default
Waterwizard icon culvert width.png CULVERT_DIAMETER m The diameter of the culvert. For throughput calculations, the culvert is assumed to have a spherical cross-section. 1
Waterwizard icon culvert height.png CULVERT_THRESHOLD m + datum The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) 0
Waterwizard icon manning.png CULVERT_N manning value The manning value of the culvert's material, which influences the flow speed. 0,014
