Sewer overflow (Water Overlay)
A sewer overflow is a point-based constructions. It must intersect with a sewer area, but does not need to intersect with an actual sewer.
{{Overlay attribute
|attributeSEWER_OVERFLOW
|unit=m + datum
|description=The height of the bottom of the sewer, relative to the average terrain height of the connected sewer. Starting from this height, the water height in the sewer must exceed the height of the terrain at the location of the overflow in order for water to flow out.
|defaultvalue=n/a
|icon=
|attribute2=SEWER_OVERFLOW_SPEED
|unit2=m3/s
|description2=The maximum speed at which water can flow out from the sewer through this overflow.
|defaultvalue2=10
|icon=
