Inlet (Water Overlay)
Revision as of 08:05, 4 April 2019 by Frank@tygron.nl (talk | contribs)
An inlet is a point-based constructions. Template:Overlay attribute
- Each Inlet attribute functions as a limit to the flow. If multiple are defined, the flow is limited by the strongest limit. If neither an INLET_Q or any threshold is defined, there will be no flow.
- A negative INLET_Q changes the Inlet to an Outlet.
