Culvert formula (Water Overlay)
Flow through culverts is based on an open channel flow calculation.
- CHreal = max( CHattr , Tleft , Tright )
The height of the water column at either end of the culvert, relative to the culvert, is calculated:
- WHleft = max(0, WLleft-CHreal)
- WHright = max(0, WLright-CHreal)
The loss coefficient for the culvert is calculated:
- U = sqrt( 1.0 / ( 1.0 + 2.0 * G * CN * CN * length / (Rh ^ (4 / 3 ) ) )
The potential flow through the culvert is then calculated:
- C = U * A * sqrt( 2 * G * abs(WHleft - WHright) )
- Δw = Δt * C / cell
Where:
- Δw = The water flow which takes place.
- cell = Cell size.
- C = The potential rate of water flow through the culvert.
- U = Loss coefficient for culverts.
- WHleft = The height of the water column relative to the bottom of the culvert on the left side of the culvert.
- WHright = The height of the water column relative to the bottom of the culvert on the right side of the culvert.
- CHreal = The CULVERT_THRESHOLD of the culvert, recalculated so the culvert is not below ground on either side.
- A = Flow area, based on the height of the water in the (circular) culvert.
- G = Acceleration factor of gravity
- CW = The CULVERT_DIAMETER attribute of the culvert.
- CHattr = The CULVERT_THRESHOLD attribute of the culvert.
- CN = The CULVERT_N attribute of the culvert.
- WLleft = The water level on the left side of the culvert, relative to datum.
- WLright = The water level on the right side of the culvert, relative to datum.
- L = The length of the culvert, calculated as the distance between the culvert's endpoints.
- Rh = The hydrological radius in the culvert[1].
- ↑ Hydraulic Radius Equations Formulas Calculator ∙ found at: https://www.ajdesigner.com/phphydraulicradius/hydraulic_radius_equation_pipe.php ∙ (last visited 2019-02-11)
