Sewer area (Water Overlay)
Revision as of 12:22, 4 April 2019 by Frank@tygron.nl (talk | contribs) (Frank@tygron.nl moved page Sewer Area (Water Overlay) to Sewer area (Water Overlay) without leaving a redirect)
Similar to water level areas, sewer areas only define a sewer storage amount in grid cells that are marked as sewered. A grid cell is marked as sewered, if:
  1. It is covered by a construction with a SEWERED attribute > 0.
  2. It is covered by a sewer area with a SEWER_STORAGE attribute > 0.
A sewer area can also pump stored sewer water to an external area outside the project. However, water that has been pumped out will remain in the external area and cannot be pumped back. By default sewers do not pump water to external areas.
Template:Overlay attribute
Sewers do not have default storage amount, but when generating them automatically in the configuration wizard, suggested values are 0,007m for older sewers and 0,04 for newer sewers. Template:WaterOverlay object nav
