Terrain water (Water Overlay)
Template:Overlay attribute
Water
Water terrains are processed by the water model in a specific manner before the simulation is started. For each water terrain in the 3D world, the bottom of the water body is treated as a land surface in the same fashion as dry land. Water is then placed on it on the surface layer, up to the level defined by the WATER_LEVEL attribute of the overlapping Water level area. Terrains not marked as water terrain are not initiated with water.
Template:WaterOverlay attribute nav
