Evaporation model (Water Overlay)
Revision as of 12:23, 10 April 2019 by Frank@tygron.nl (talk | contribs)
All forms of evaporation can generally be configured by setting the weather's evaporation rate. If the evaporation rate is set to 0, no evaporation will take place in any form.
Surface evaporation model
Water on the surface can evaporate. The amount is based on the weather's evaporation factor and the grid cell's evaporation factor. These two multiplied result in a evaporation amount per second, which is done for each grid cell individually. Zero evaporation is also allowed.
The evaporation factor of a grid cell is determined during the model initialization phase. Per grid cell the evaporation factor is selected by:
Underground evaporation model
Underground evaporation can be implicitly activated or deactivated by setting the relevant properties of all terrain types and constructions to appropriate evaporation values. If the relevant properties are set to 0, no underground evaporation will take place. Underground evaporation is also explicitly deactivated when the Underground model is deactivated.
The rate of evaporation is determined by the weather's evaporation rate, and either the construction's WATER_EVAPORATION_FACTOR or the surface terrain's WATER_EVAPORATION_FACTOR.
Template:WaterOverlay nav
