Surface model (Water Overlay)
The surface is defined by the terrain height in the project. The terrain height is further influenced by the height of constructions present in the project (bounded by DESIGN_FLOOD_ELEVATION_M) and by the BREACH_HEIGHT of breaches.
Terminology
| symbol | |
| B | surface elevation of grid cell |
| h | water height of grid cell |
| w | water level of grid cell |
w = h + z
Surface water level initialization
