Surface model (Water Overlay)
Revision as of 09:59, 11 April 2019 by Frank@tygron.nl (talk | contribs)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface.
Terminology
symbol
B surface elevation of grid cell
h water height of grid cell
w water level of grid cell
w = h + z
Surface water level initialization
Template:WaterOverlay nav
