Surface model (Water Overlay)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface. In order to simulate flowing water, the project area is discretized into x by y cells, based on the configured grid cell size. Next, the model requires a descriptions of rules. For this we use the Saint-Venant system, which reads:
Terminology
![](/w/images/e/e1/Waterlevel_schematic.png)
symbol | |
B | surface elevation of grid cell |
h | water height of grid cell |
w | water level of grid cell |
w = h + z
Surface water level initialization
