Surface model (Water Overlay)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface. In order to simulate flowing water, the project area is discretized into x by y cells, based on the configured grid cell size.
Secondly a model is required which describes the rules that need to be followed. For this we use the two-dimensional Saint-Venant system, which reads:
In the Tygron Platform this model is implemented using the Well balanced, positivity presevering central-upwind scheme described in [1]
Symbol | |
B | surface elevation of grid cell |
h | water height of grid cell |
w | water level of grid cell |
w = h + z
Surface water level initialization
- ↑ Cite error: Invalid
<ref>
tag; no text was provided for refs namedref-reference
