Sewer model (Water Overlay)
Sewers can be implicitly activated and deactivated by adding or removing Sewer areas. If no sewer areas exist, no sewers are available in the water model and no water can flow to and from there.
Sewer Overflow
Rain water can flow from a sewer overflow back onto the surface via a Sewer overflow. A sewer overflow removes water from the sewer and places it on the surface of the cell where the overflow is located. The speed at which this water flows is determined by the SEWER_OVERFLOW_SPEED.
External area
Sewer water can also be transported to a region outside the project area. This is controlled through the sewer area's SEWER_PUMP_SPEED. Sewer water removed this way is removed from the hydrological model and cannot return back into the project area. The sewer pump speed cannot be negative; it is not allowed to pump water from outside the project area into the sewer.
Template:WaterOverlay nav
