Sewer model (Water Overlay)
Revision as of 09:53, 12 April 2019 by Frank@tygron.nl (talk | contribs)
Sewers can be implicitly activated and deactivated by adding or removing Sewer areas. If no sewer areas exist, no sewers are available in the water model and no water can flow to and from there.
Sewer Overflow
Rain water can flow from a sewer back onto the surface via a Sewer overflow. The location of the sewer overflow marks the exit at which water flows out of the sewer. The (maximum) speed at which this water flows is determined by the SEWER_OVERFLOW_SPEED.
For sewer overflow to occur, two criteria have to be met. Firstly, the amount of water in the sewer relative to the sewer's storage capacity must exceed the SEWER_OVERFLOW_THRESHOLD. Secondly, the water level in the sewer must exceed the water level at the exit of the server overflow.
The SEWER_OVERFLOW_THRESHOLD should always be a fraction of the sewer's storage capacity.
The water level of the sewer is sum of the water height in the sewer and the height at which the sewer overflow is situated. This height is stored in the SEWER_OVERFLOW attribute of the sewer overflow construction. Conceptually, the height is the sewer is therefore directly related to the sewer overflow height.
External area
Sewer water can also be transported to a region outside the project area. This is controlled through the sewer area's SEWER_PUMP_SPEED. Sewer water removed this way is removed from the hydrological model and cannot return back into the project area. The sewer pump speed cannot be negative; it is not allowed to pump water from outside the project area into the sewer.
Template:WaterOverlay nav
