Infiltration model (Water Overlay)
File:Infiltration model.png
When water infiltrates from the surface, it infiltrates at a speed dictated by the surface terrain's GROUND_INFILTRATION_MD attribute, the underground terrain's GROUND_INFILTRATION_MD attribute, or (if present) by the construction's GROUND_INFILTRATION_MD, whichever value is lowest. The least porous material present will always serve as a bottleneck for the water to flow through, even if the other layers allow for a high rate of infiltration.
Exfiltration Water stored in the underground saturated zone can also exfiltrate out of the underground and back onto the surface, if the groundwater level relative to datum exceeds the neighboring cell's surface water level relative to datum. The amount of water which can flow from the underground of one cell onto the surface of an adjacent cell is dictated by the underground terrain's GROUND_INFILTRATION_MD.
