How to add and remove an Area
Revision as of 08:23, 15 April 2019 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page How to add and remove an area to How to add and remove an Area without leaving a redirect)
How to add an Area to the project.:
- Select Current situation in the ribbon header.
- Select Areas in the ribbon bar.
- Select 'Add' at the bottom of the left panel.
- Notice that the new Area has been added to the list of Areas.
How to remove an Area from the project.:
- Select the Area that should be removed in the left panel.
- Select 'Remove' at the bottom of the left panel.
- Notice that the Area has been removed from the list of Areas.
