Weir formula (Water Overlay)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
- hs = max(0, max( wl, wr ) - zw)
- hd = max(0, min( wl, wr ) - zw)
For free flow, capacity is calculated directly:
- Cfree = fw,d * cw * ww * ( hs - hd )3/2
For submerged flow, a culvert-like calculation is used:
- Csubmerged = Uloss * A * sqrt( 2 * g * ( hs - hd ) )
- hratio = hd / hs
- C = min( Csubmerged , Cfree) if hratio > 0,5
- C = Cfree otherwise
- Δw = Δt * C / cell
Where:
- Δw = The water flow which takes place.
- cell = Cell size.
- C = The potential rate of water flow across the weir.
- WHrelative = The ratio of water heights on either side of the culvert.
- Cfree = The potential rate of water flow across the weir, based on a free flow calculation.
- Csubmerged = The potential rate of water flow across the weir, based on a submerged calculation.
- hs = The height of the water column relative to the top of the weir, on the side with the highest water level.
- hd = The height of the water column relative to the top of the weir, on the side with the lowest water level.
- Uloss = Loss coefficient for submerged weirs (0,9).
- A = Flow area, based on the highest water column height relative to the top of the weir, and the weir width, defined by the WEIR_WIDTH attribute of the weir
- g = Acceleration factor of gravity
- fw,d = Dutch weir factor, set to 1.7
- cw = The WEIR_COEFFICIENT attribute of the weir.
- zw = The WEIR_HEIGHT attribute of the weir.
- ww = The WEIR_WIDTH attribute of the weir.
- wl = The water level on the left side of the weir, relative to datum.
- wr = The water level on the right side of the weir, relative to datum.
