Weir formula (Water Overlay)
Revision as of 10:04, 15 April 2019 by Frank@tygron.nl (talk | contribs)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
hs = max(0, max( wl, wr ) - zw)
hd = max(0, min( wl, wr ) - zw)
hratio = hd / hs
C = min( Csubmerged , Cfree) if hratio > 0,5
C = Cfree otherwise
For free flow, capacity is calculated directly:
Cfree = fw,d * cw * ww * ( hs - hd )3/2
For submerged flow, a culvert-like calculation is used:
Csubmerged = Uloss * A * sqrt( 2 * g * ( hs - hd ) )
Δw = Δt * C / cell
Where:
  • cell = Cell size.
  • C = The potential rate of water flow across the weir.
  • hratio = The ratio of water heights on either side of the culvert.
  • Cfree = The potential rate of water flow across the weir, based on a free flow calculation.
  • Csubmerged = The potential rate of water flow across the weir, based on a submerged calculation.
  • hs = The height of the water column relative to the top of the weir, on the side with the highest water level.
  • hd = The height of the water column relative to the top of the weir, on the side with the lowest water level.
  • Uloss = Loss coefficient for submerged weirs (0,9).
  • A = Flow area, based on the highest water column height relative to the top of the weir, and the weir width, defined by the WEIR_WIDTH attribute of the weir
  • g = Acceleration factor of gravity
  • fw,d = Dutch weir factor, set to 1.7
  • cw = The WEIR_COEFFICIENT attribute of the weir.
  • zw = The WEIR_HEIGHT attribute of the weir.
  • ww = The WEIR_WIDTH attribute of the weir.
  • wl = The water level on the left side of the weir, relative to datum.
  • wr = The water level on the right side of the weir, relative to datum.
Template:WaterOverlay nav
