Sewer Overflow formula (Water Overlay)
The sewer base height is located at the height indicated by the sewer overflow:
- Bs = Bso
The sewer overflow height is calculated as:
- Ho = Hs * To
The water level at the sewer is then:
- ws = hs + Bs
Water only flows out of the sewer iff:
- hs > Ho and
- hs + Bs > wo
The amount that can overflow relies on both the sewer overflow itself as well as the sewer overflow threshold:
The flow is then calculated with the SEWER_OVERFLOW_SPEED attribute of the sewer overflow.
- Δh = min ( hs - Hs , ws - wo)
- Δw = min( max( 0 , hs ), Δt * vo
- Cthreshold = max( 0 , hs - Hs * Ts )
- Cheight = max( 0, Tsewer + H>sub>o + hsewer - Toverflow )
- C = min ( Cthreshold, Cheight )
Actual overflow is then calculated:
- Δw = min( 0 , C * Σsewer , Δt * SOS )
- hs = The height of the water column in the sewer.
- HS = The SEWER_STORAGE attribute of the sewer area, the maximum water height allowed in the sewer.
- Δw = The amount of sewer overflow which takes place.
- C = The amount of water that can overflow out of the sewer
- Cthreshold = The amount of water that could overflow, based on the sewer overflow threshold.
- Cheight = The amount of water that could overflow, based on the properties of the sewer overflow.
- Σsewer = The surface area of the sewer.
- Tsewer = The average height of the terrain where the sewer is present, relative to datum.
- Toverflow = The height of the terrain at the centerpoint of the sewer overflow, relative to datum.
- Ho = The surface height of the sewer, determined by SEWER_OVERFLOW attribute of the sewer overflow.
- SOS = The SEWER_OVERFLOW_SPEED attribute of the sewer overflow.
- SOT = The SEWER_OVERFLOW_THRESHOLD.
- The sewer's height relative to datum is not defined in the Sewer itself. It is relative to the sewer overflow and determined by the SEWER_OVERFLOW attribute of the overflow.
