Sewer Overflow formula (Water Overlay)
Revision as of 12:28, 15 April 2019 by Frank@tygron.nl (talk | contribs)
The sewer base height is located at the height indicated by the sewer overflow:
- Bs = Bso
The sewer overflow height is calculated as:
- Ho = Hs * To
The water level at the sewer is then:
- ws = hs + Bs
Water only flows out of the sewer iff:
- hs > Ho and
- hs + Bs > wo
The amount that can overflow relies on both the water level at the sewer overflow itself as well as the sewer overflow threshold and the stored sewer water:
- Δh = min ( hs - Hs , ws - wo)
The flow is then calculated with the SEWER_OVERFLOW_SPEED attribute of the sewer overflow.
- Δw = min( Δh, Δt * qo / As)
- Bo = The height of the terrain at the centerpoint of the sewer overflow, relative to datum.
- Bs = The assumed surface height of the sewer, relative to datum.
- hs = The height of the water column in the sewer.
- HS = The SEWER_STORAGE attribute of the sewer area, the maximum water height allowed in the sewer.
- Δw = The amount of sewer overflow which takes place.
- As = The surface area of the sewer.
- Ho = The surface height of the sewer, determined by SEWER_OVERFLOW attribute of the sewer overflow.
- SOS = The SEWER_OVERFLOW_SPEED attribute of the sewer overflow.
- SOT = The SEWER_OVERFLOW_THRESHOLD.
- The sewers area is counted as the amount of sewered grid cells times the size of a grid cell.
- The sewer's height relative to datum is not defined in the Sewer itself. It is relative to the sewer overflow and determined by the SEWER_OVERFLOW attribute of the overflow.
