Sewer Overflow formula (Water Overlay)
Revision as of 14:04, 15 April 2019 by Frank@tygron.nl (talk | contribs)
The sewer base height is located at the height indicated by the sewer overflow:
Bs = Bo
The water level at the sewer is then:
ws = hs + Bs
The sewer overflow threshold height Ho within the sewer is calculated as:
Ho = Hs * To
Water only flows out of the sewer iff:
hs > Ho and
hs + Bs > wo
The amount that can overflow relies on both the water level at the sewer overflow itself as well as the sewer overflow threshold and the stored sewer water:
Δh = min ( hs - Ho , ws - wo)
The flow is then calculated with the SEWER_OVERFLOW_SPEED attribute of the sewer overflow and the maximum speed with which water can flow through the sewer overflow:
Δw = min( Δh, Δt * qo / As)
The amount of water added to the exit cell(s) of the sewer overflow:
Qo = Δw * As
  • Bo = The height of the terrain at the centerpoint of the sewer overflow, relative to datum.
  • Bs = The assumed surface height of the sewer, relative to datum.
  • wo = The water level at the sewer overflow's exit, relative to datum.
  • ws = The water level of the sewer, relative to datum.
  • hs = The sewer water height.
  • HS = The SEWER_STORAGE attribute of the sewer area, the maximum water height allowed in the sewer.
  • Δw = Water level change in the sewer, due to sewer overflow.
  • As = The surface area of the sewer.
  • qo = The SEWER_OVERFLOW_SPEED attribute of the sewer overflow.
  • To = The SEWER_OVERFLOW_THRESHOLD, the threshold factor indicating the fraction of the sewer's storage height that is blocked by the sewer overflow 's threshold.
  • The sewers area is counted as the amount of sewered grid cells times the size of a grid cell.
  • The sewer's height relative to datum is not defined in the Sewer itself. It is relative to the sewer overflow and determined by the SEWER_OVERFLOW attribute of the overflow.
Template:WaterOverlay nav
