Pump formula (Water Overlay)
Revision as of 14:41, 15 April 2019 by Frank@tygron.nl (talk | contribs)
Pumps are hydraulic structures can pump water from areas with a lower water level to areas with a higher water level. A negative pump speed is also allowed. In this article we will refer to this as a drain.
The amount being pumped or drained is dependent on the water levels on both sides of the pump.
Case 1: Pumping:
First the capacities are calculated.
If a positive Pump q is defined:
Qp,t = Δt * qt
If a lower threshold Tl,t is defined as well:
Ql,t = max ( 0, wl,t - Tl,t )
If an upper threshold Tu,t is defined as well:
Qu,t = max ( 0, Tu,t- wt,u )
If a capacity Qtotal is defined:
Qc = Qtotal- ΣQ0..t-1
After calculating the capacities, the actual water pumped upwards is calculated. If any of the terms are undefined, they are not included.
Δw = max( 0 , min( Qlth,Quth , Qt , Qc ) ) / A
Case 2: Draining:
If a negative Pump q is defined:
Qp,t = Δt * qt
Ql,t = min ( 0, wl,t - Tl,t )
Where:
  • wt,l = The water level at the lower water level entry on at time t, relative to datum.
  • wt,u = The water level at the upper water level entry on at time t, relative to datum.
  • Tl,t = The LOWER_THRESHOLD attribute of the inlet at time t.
  • Tu,t = The UPPER_THRESHOLD attribute of the inlet at time t.
  • qt = INLET_Q attribute at time t.
  • Qtotal = The INLET_CAPACITY attribute of the inlet.
  • Q0..n = The calculated previous amounts of flow.
  • Ql,t = The amount of water inflow desired based on the inlet's LOWER_THRESHOLD attribute.
  • Qu,t = The amount of water outflow desired based on the outlet's UPPER_THRESHOLD attribute.
  • Qt = The amount of water inflow (or outflow when negative) possible based on the INLET_Q attribute and timestep Δt.
  • Qc = The amount of water outflow possible based on the total capacity of the outlet.
  • A = Size of the Inlet/Outlet area in m2, based on the amount of cells and cell size. Current implementation only has one cell.
Template:WaterOverlay nav
