UK Benchmark 6 (Water Module)
Revision as of 09:38, 29 April 2019 by Frank@tygron.nl (talk | contribs) (Frank@tygron.nl moved page UK Benchmark (Water Module) to UK Benchmark 6 (Water Module) without leaving a redirect: new location)
description
Tygron Platform version: 2019.0.0 DEV 61.0 Date executed: 2018-07-09
Characteristics:
- Dimensions: 20X the values below
- Roughness: uniform manning = 0,05 m/s1/3
- Initiële conditions: 8m in reservoir, 0,4m in floodplain
- Modelgrid resolution: 2m
results
Waterlevels and profiles at the locations indicated in figure above
Velocity profiles
- Environmetal Agency (2013). Benchmarking the latest generation of 2D hydraulic modelling packages ∙ report Report – SC120002 ∙ found at: https://consult.environment-agency.gov.uk/engagement/bostonbarriertwao/results/appendix-6---neelz--s.---pender--g.--2013--benchmarking-the-latest-generation-of-2d-hydraulic-modelling-packages.-bristol_environment-agency.pdf (last visited 2018-08-03)
