Ground evaporation formula (Water Overlay)
- Hunsat = Hsurface - WLunderground
- Csat = max( 0 , min( RD , GBDM ) - Hunsat ) * WSP
- Cunsat = max( 0 , min( RD , Hunsat ) ) * ( Wunsat / Hunsat )
- Δwunsat = min( Cunsat , Δt * Eweather * Etop )
- Δwsat = min( Csat , (Δt * Eweather * Etop) - Δwunsat )
- Δw = Δwunsat + Δwsat
Where:
- Δw = The total amount of evaporation which takes place.
- Δwunsat = The amount of evaporation which takes place from the unsaturated zone.
- Δwsat = The amount of evaporation which takes place from the saturated zone.
- Cunsat = The amount of evaporation that can take place from the unsaturated zone.
- Hunsat = The height (column) of the unsaturated zone.
- Wunsat = The amount of water in the saturated zone. The height of the water column if the equivalent amount of water was placed on the surface.
- WLunderground = The groundwater level, relative to datum.
- Hsurface = The terrain height in the cell, relative to datum.
- RD = The ROOT_DEPTH_M of the construction if present, the ROOT_DEPTH_M of the surface terrain otherwise.
- GBDM = The GROUND_BOTTOM_DISTANCE_M of the Water Overlay. (effectively available height in the underground).
