Surface infiltration formula (Water Overlay)
Revision as of 13:18, 14 June 2019 by Rudolf@tygron.nl (talk | contribs)
First, the infiltration capacities are calculated:
- Cwater = Wsurface
- Ctop = max( Icon, Isurf )
- Isurf = 0 if a construction is present
- Icon = 0 if no construction is present
Then the actual infiltration:
- Δw = min( Cwater , Δt * Ctop)
Where:
- Cwater = The amount of infiltration that can take place based on the amount of water on the surface.
- Ctop = The amount of infiltration that can take place based on the infiltration values present.
- Wsurface = The amount of water (the water column) on the surface.
