How to add and configure hydraulic structures (Water Overlay)
Manually add and remove hydraulic structures
How to add a hydraulic structure (example: inlet):
- From the Buildings dropdown select "Add Building".
- Name your new building.
- Click Change Function.
- Select (1) the correct category > (2) the desired function > (3) Apply.
- Click Draw Area.
- Select (1) one or more grid cells on the map for the desired location of the new building > (2) Apply Selection.
- In the Configuration Wizard of the Flooding Overlay at (1) the corresponding step > select (2) the new building > (3) Next.
- Finally, test the new hydraulic structure by running the simulation.
1. Select Add Building.
2. Name your new building.
3. Click Change Function.
4. Select (1) the correct category > (2) the desired function > (3) Apply.
5. Click Draw Area.
6. Select (1) one or more grid cells on the map for the desired location of the new building > (2) Apply Selection.
7. In the Configuration Wizard of the Flooding Overlay at (1) the corresponding step > select (2) the new building > (3) Next.
8. Finally, test the new hydraulic structure by running the simulation.
How to remove a hydraulic structure (example: inlet):
- From the Buildings dropdown select "Show Buildings".
- Select (1) the inlet you whish to remove > (2) Remove > (3) Yes.
1. Select Show Building.
2. Select (1) the building you wish to remove > (2) Remove > (3) Yes.
