Result types (Heat Overlay)
Revision as of 14:16, 10 September 2019 by Frank@tygron.nl (talk | contribs)
List of Result Types
Icon Result type Unit Display mode Description
BOWEN_RATIO Date
HEAT_FOLIAGE Start
HEAT_PET Date
HEAT_SHADE Date
HEAT_SKY_VIEW Start
HEAT_SKY_VIEW_AVG Date
HEAT_TEMPERATURE_ATMOSPHERE Date
HEAT_UHI Date
HEAT_VEGETATION Date
HEAT_VEGETATION_AVG Date
HEAT_WIND_SPEED Date
Template:Unit disclaimer (Water Overlay)
