Result types (Heat Overlay)
Revision as of 15:31, 10 September 2019 by Frank@tygron.nl (talk | contribs) (→List of Result Types)
The Heat Module of a Heat Overlay performs complex calculations and can generate multiple types of results per timeframe. A timeframe in the Heat Overlay correspond to a date and time for which a result will be calculated. This date and time will be relative to the project's time zone.
Icon | Result type | Unit | Display mode | Description |
BOWEN_RATIO | Date | |||
FOLIAGE | Start | |||
HEAT_PET | Date | |||
HEAT_SHADE | Date | |||
HEAT_SKY_VIEW | Start | |||
HEAT_SKY_VIEW_AVG | Date | |||
HEAT_TEMPERATURE_ATMOSPHERE | Date | |||
HEAT_UHI | Date | |||
HEAT_VEGETATION | Date | |||
HEAT_VEGETATION_AVG | Date | |||
HEAT_WIND_SPEED | Date |
Template:Unit disclaimer (Water Overlay)
- Date: The data is dependent on the timestep, which corresponds to a date and time. In case the Average timeframe option is selected, the last timeframe will present the average values of all previous timesteps for that particular Result Type.
