Result types (Heat Overlay)
The Heat Module of a Heat Overlay performs complex calculations and can generate multiple types of results per timeframe. A timeframe in the Heat Overlay correspond to a date and time for which a result will be calculated. This date and time will be relative to the project's time zone.
List of Result Types
Icon Result type Unit Display mode Description
BOWEN_RATIO Date
FOLIAGE m Start
PET °C Date
PET_RELATIVE °C Date
SHADE Indicates whether a cell is in the shade or not based on sun ray calculations. Date
SKY_VIEW Start
SKY_VIEW_AVG Date
TEMPERATURE_ATMOSPHERE °C Date The calculated atmospheric temperature, based on the UHI, sun motion factor and the measured temperature.
UHI Date The calculated urban heat island effect.
VEGETATION Date The fraction of vegetation per square meter.
VEGETATION_AVG Date The calculated average vegetation based on the cells' individual vegetation fraction.
WIND_SPEED m/s Date The wind speed calculated for the height of 1.2 meters above ground.
Template:Unit disclaimer (Water Overlay)
  • Date: The data is dependent on the timestep, which corresponds to a date and time. In case the Average timeframe option is selected, the last timeframe will present the average values of all previous timesteps for that particular Result Type.
