Result types (Heat Overlay)
Revision as of 16:04, 10 September 2019 by Frank@tygron.nl (talk | contribs)
The Heat Module of a Heat Overlay performs complex calculations and can generate multiple types of results per timeframe. A timeframe in the Heat Overlay correspond to a date and time for which a result will be calculated. This date and time will be relative to the project's time zone.
List of Result Types
Icon Result type Unit Display mode Description
BOWEN_RATIO Date-Time
FOLIAGE m Start The initial and optional calculated foliage height, depending on the source of the foliage height.
PET °C Date-Time The calculated physiological equivalent temperature.
PET_RELATIVE °C Date-Time The calculated PET temperature subtracted by the calculated atmospheric temperature
SHADE Date-Time Indicates whether a cell is in the shade or not based on sun ray calculations.
SKY_VIEW Start The calculated sky view factor.
SKY_VIEW_AVG Date-Time The calculated average of individual calculated sky view factors.
TEMPERATURE_ATMOSPHERE °C Date-Time The calculated atmospheric temperature, based on the UHI, sun motion factor and the measured temperature.
UHI Date-Time The calculated urban heat island effect.
VEGETATION Date-Time The fraction of vegetation per square meter.
VEGETATION_AVG Date-Time The calculated average vegetation based on the cells' individual vegetation fraction.
WIND_SPEED m/s Date-Time The wind speed calculated for the height of 1.2 meters above ground.
Template:Unit disclaimer (Water Overlay)
  • Date-Time: The data is dependent on the timestep, which corresponds to a date and time. In case the Average timeframe option is selected, the last timeframe will present the average values of all previous timesteps for that particular Result Type.
