Sky view factor calculation model (Heat Overlay)
Sky limiters
The model starts by determining per grid cell what the height of obstacles are on that grid cell. An obstacle can be:
  • a building,
  • foliag. ,The top of foliage is used as the obstacle height.
  • terrain height.
Next, for each grid cell, the sky view sections are calculated for each consecutive pair of rays. In the previous image, you can see one such section.
Sky exposure factor versus sky view factor
In literature, two sky parameters are mentioned that are sometimes confused: Sky exposure and sky view factor. The sky exposure is related to the sky view dome (3D). The sky view factor is related to the projection of the view dome to the horizontal plane. Here we call the projected circle the view circle. In the second image, you can distinguish a sky view section on the dome and a section projected on the view circle.
Why is the sky view factor selected?
The reason why the sky view factor is selected and not the sky exposure, is because the sky view factor result weights objects closer to the top of the sky view dome higher than objects further away. This is caused by the projection from 3D to 2D. And it is desirable, because the sky view factor is directly related to the reflected radiation in the used formula's.
Sky view factor
The sky view factor can be calculated by dividing the sky view area by the area of the circle of the horizontal plane. The sky view area is simply the sum of the areas of each section. Each section area is calculated as an arc section.
  • The size of the dome and sky circle do not matter, they can simply be a unit sphere and circle. Only the angle between the ray and the horizontal plane determine the sky view sections.
