Surface infiltration formula (Water Overlay)
First, the infiltration capacities are calculated:
- Cwater = Wsurface
- Ctop = max( Icon, Isurf )
- Isurf = 0 if a construction is present
- Icon = 0 if no construction is present
Then the actual infiltration: Failed to parse (unknown function "\math"): {\displaystyle \Delta w = min( C_{water} , \Delta t \cdot C_{top}<\math> Where: * <math>\Delta w} = The surface infiltration which takes place.
- = Computational timestep.
- = The amount of infiltration that can take place based on the amount of water on the surface.
- = The amount of infiltration that can take place based on the infiltration values present.
- = The amount of water (the water column) on the surface.
- = The GROUND_INFILTRATION_MD of a construction on a specific cell (if present).
- = The GROUND_INFILTRATION_MD of the surface terrain type. This value should be interpreted as the vertical conductivity (Kv) of the sub-soil.
Related
